Blowing smoke
minimefx
46
vr wagon, vx executive
I let my car idle for 10min and when i take off it blow a puff of smoke. It only does it after idling for a while.Whats wrong with it?
mag
59
South OZ Adelaide
VY Series 1 Acclaim 2003
Sounds like valve guide seals..:)
burnz
dah dut dut da dah
springfield
VFII SS ute M6
mag on the money valve seal
your at $30 for a set of 12
plus a couple a hundred to have it done
unless you do it yourself
whith a compressor and the engine at tdc of each cylender
this will hold the valves up while you remove the retaining clips/springs
and replace rubber sleves this will save money and nowing the satisfaction of doing it yourself
minimefx
46
sweet thank for that guys i will have a go at fixing on the weekend
harry3
72
vl berlina wagon 6cyl
I ouldnt leave an engine idling for that long, especially from cold
when blowing smoke. always suspect an overfull sump, drain it and measure what comes out, its been known for the wrong dipstick to be fitted, or the dipstick to break, giving a false reading
