Blue/black 202 harmonic balancer
glennho
60
PERTH ,Darch WA
2006 VE SS -1977 HX Premier,2012 Hilux 4x4
Hey, I probably know the answer to this but want to make sure as its been a while since ive worked on a 202 engine. Will a blue /black 202 harmonic balancer fit a red 202 crank. Pretty sure it will but want to make sure. Thanks
the_boozer
no more VK
51
Shitsville Morwell
hilux
the timing mark is in a different spot compare it and mark off the old one.if using a blue balancer on a red motor
vc commodore
Like the Leyland Brothers
VC, VH and VY
On the balancer or timing case cover
Black crank in a blue block
Red motor
the_boozer
no more VK
51
Shitsville Morwell
hilux
you said you'd done it what did you notice when you did it ?
It only matters when you want to use the timing light or change the distributor.
vc commodore
VC, VH and VY
The timing mark is still in the same spot, no matter what balancer you use on what motor....
So you've lost me with this comment
"the timing mark is in a different spot compare it and mark off the old one.if using a blue balancer on a red motor"
The main issue I strike with these balancers is the rubber ring inbetween the outer ring and inner allows the outer ring to move when they get old...The outer ring has the timing mark on it, so this means setting the timing can be difficult if it has moved
the_boozer
no more VK
51
Shitsville Morwell
hilux
Did the zero point on the balancer move you seam to be implying it didn't?
vc commodore
VC, VH and VY
No...When the rubber inbetween the outer and inner portion of the balancer gets old, it doesn't hold the outer ring, where the timing mark is, in it's original spot....So when you go to set the timing, it'll give you a false correct timing.
In my case, when I had to change dizzies, mine had moved, so my 6 degrees BTDC setting turned out to be 10 degrees BTDC to be correct, because it had moved slightly
the_boozer
no more VK
51
Shitsville Morwell
hilux
Everytime I had a rubber deteriorate and move the only thing that stopped it flying off was the ac pulley ,
