bonnet adjustment
spice_man2069
VN SS
i did a search but i didnt seem to come up with much,
my problem is i cant open my bonnet just by puling the lever under the dash i need a second person to push down on the bonnet and then to get their fingers under it and lift it up so you can use the catch, what i am wondering is how i go about adjusting my bonnet relese so that it actually pops.
thanks James
gungazza
68
west suburbs
executive vt 5.0lt VZ CREWMAN
you need to adust the pin with the spring on it lossene it and move it around you will find the right spot eventually
Bax
Projecting
40
QLD
Nothing
Take it into a panel beater? I hate doing bonnets, they always sit differently for me. Is there any signs of paint freshness underneath where it should be?
One side at a time playing around.
If you ever take iti off, trace around it before you take out the bolts.
bangers
45
NSW
EL FALCON XR6
i had the same trouble. use a flat blade screw driver and turn the pin anti-clockwise a few turns. then tighten the nut up. it may take a few times to get it how you like.
