boot stuck closed - help needed (I'm not inside)
bjsa06
adelaide
VL Exec, VT Belina Wagon, VY Commodore
The boot on my VY is stuck closed. Both the remote key button and glovebox button will not open it. I can hear the motor in the back trying to release the latch, but it's still closed.
I have managed to open it by crawling into the boot through the reclined backseat and pulling on the emergency cable (incase you get trapped inside). But this is not a long term solution.
Any help appreciated.
Thanks
goldcoast
supercharged vt II acclaim
does it open if you lift the boot/put some pressure on it while pressing the unlock button??
:rofl2: @ (im not inside)
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
The boot lock actuation rod would have broken.
Go to Holden/wherever and tell them what is happening and that you need the boot actuator rod and they will sell you the right part. It's roughly 3 inches long and connects the boot lock to the actuator. Which is why remote release wont work
bjsa06
adelaide
I have tried this. No Go. I'm off to holdens to get the spare listed above
bjsa06
adelaide
Thanks Sabbath, are you aware of any info regarding how to replace it? Or is it obvious when I start the job?
yZoH
//There Ain't No Rest For The Wicked...
S/E Subs, Melb
www.lolwut.com
(0.o')
Thread title made me lose my ****!!!
edals
hmmm i have a similar issue i guess, But its not the rod thats broken.
I Find if the boot is closed a little too hard, the boot will not release and the motor wont pull the lock when you press the button.
So this ends up with using the emergency release behind the seats.
If the boot is closed very gently its fine.
Any ideas ?
goldcoast
Any ideas ?
have a go at screwing in/out those little screw in rubbers around the bottom of the boot... i had to screw mine out a bit so it lifted the boot a tad for it to work(everytime)....
edals
Thanks mate ill give it a go :)
