I rang that Torqueline Differential mob in Victoria about their diff centre. He said it's a copy of the Harrop / Eaton True trac centre. Assured ( convinced ? ) me of the quality.
Reckons a harrop / eaton centre was pulled completely apart and tested for metallurgy composition, then sent overseas for manufacture with the same metallurgy equivalant, then tested again here on completion. Sounds pretty good to me, even if it's 80% as good as the harrop / eaton then will not break on me for my intended purpose.
I know some of you reckon the factory LSD will be OK, but I will eventually have to take it apart and remove the 3.08 and put in a 3.9 The tyres ( 235 / 75 / 15 ) will be too tall for the overdrive to come in at around 90 km , which is where my old VR used to change ( unless the T700 can be adjusted ? )
Besides all that, blokes are asking $250 - 300 for a used LSD diff. At just over $600 for Ebay job, I reckon that's a bargain.
Is it worth considering an upgrade on that --- what suggestions do you have please.
