bottom rad hose
luckyvt94
30
Hobart Tasmania
vz Thunder SS
My bottom radiator hose keeps blowing off. It's done it 3 times in about 2 weeks. Does anyone know what could be causing it. I've replaced the radiator and cap.
Any help will be appreciated
Aaron6.93
2003 VY Calais L67
Do you have the correct cap? It should say 135kpa on it. The radiator cap is designed to release pressure when the 135kpa limit is reached. If you have the wrong cap it can build up pressure an pop off your hoses. If that's not the problem you may need new hoses and hose clamps.
acarmody
Donati..Whoa Green
VX Berlina
Yea it's 135kpa. That was going to be next on the list
Could still be defective. Spring may be getting stuck or not opening. Try another one to be safe.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
What sort of hose clamps do you have?
If it's the spring type, get rid of them and get the worm drive type.
Or better still, these ones.
luckyvt94
30
Hobart Tasmania
vz Thunder SS
It's got worm drive ones any idea where I could grab a few of them from?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Ebay have the T bolt clamps t bolt clamp | eBay and so do Autobarn.
The worm drive ones you can get anywhere, servos, auto and hardware shops.
Pollushon
Boost gives me a bar....
VY SS
Standard clamps should be plenty, I'd maybe try to identify the problem or the it may just find the next path of least resistance.
