1LOWVX
How Low Can You Go
The fuel pump should shut off as my mates does and his brothers SS does as well. Is it gas injection or a impco cause that may make a diffrence but if your car feels and sounds like its flooding on petrol then your O rings on the base of your injectors are worn or cracked from running on gas to much, as that happened to me but not from gas as i don't have it nor want it. But if you change or injectors i recommend you change your plugs as the may be fowled up and after that your car will thank you for it
