Not_An_Abba_Fan
Exhaust Guru
- Aug 18, 2006
- 14,639
- 1,364
- 113
- Location
- Bunbury, WA
- Strange Rover
I have an old Triumph TR6 - their brakes are notoriously hard to bleed- it's very difficult to get a full pedal. Some of the blokes jam the brake pedal down hard overnight with a stick then rebleed the next day. The theory is that the pressure and time cause any microbubbles in the fluid to coalesce into bigger bubbles that will bleed out.
I've never needed to do it with a Holden but if your running out of options it might be worth a try.
Try doing a 40 series Landcruiser with slave cylinders top and bottom, have to unbolt the backing plate and rotate it to get all the air out. Unless you had a pressure bleeder, those things are worth their weight in gold.
