brake light and dash lights fault
flawless
VT Executive
i recently installed a new headunit in my 98 Vt commodore,
all wires were used except the folowing:
Brown/wht = dimmer in
Grey = dimmer out
black/wht = ground (i made a seperate ground)
Yellow/Black = Phone mute
now for sum reason my brake lights wont work and also my dash lights dont work, i replaced fuses and they still dont work
ducatis
33
Lennox Head
VS UTE
Hey i recently had the same problem, the brake and dash lights are on the same circuit. My problem was that the tail light globe was shorting.
Mitch
flawless
VT Executive
ok cool wot did u do to fix the problem?
maginoodle
vy series2 ss crewman
pull out your brake light bulbs. and see if the dash lights work. if they do replace the bulbs one at a time until you find the faulty one
flawless
VT Executive
thanks for the advice will try it after work, fingers crossed :)
flawless
VT Executive
ok i took all 3 brake bulbs out and replaced fuses, but still the dash light fuse blew and so did the brake fuse when i stepped on the brake.
is there any other way to check what the problem is or should i just take it to a autoelectrician
-Junior-
S.W. Sydney
vn auto
May not be but check the wiring harness behind the boot liner on the drivers side near the fuel flap. The wiring may have rubbed through on the sheet metal.
