Brakes lights
Gourav
27
oran park
VE06C Omega
Can anyone please help me out my holden Omega 2009 brakes lights stay on all the time even if u turn off the engine ( ignition). Then i have to take out the brake light fuse to turn tht off
vc commodore
Like the Leyland Brothers
VC, VH and VY
Replace the brake light switch at the brake pedal
kwaka738
Wantirna, Victoria
VE MY09 Berlina Sportwagon
Let's think cheap and eliminate the globes first before we splash the cash.
Remove the passenger brake light globe (it's probably also the parking light globe as well, i.e. it has 2 filaments).
Does the problem go away or are the driver's side brake light and back window brake light globe still on?
If the problem didn't go away put that globe back.
Remove the driver's side brake light globe. Did the problem go away?
(I have seen some IDIOT put a single filament indicator globe in the spot where the dual filament brake/parker bulb was to go. It shorted the brake light line to the parker light line. I'm just trying to eliminate one of the globes feeding 12 volts back onto the brake light 12V line.)
  • Like
Reactions: Lex
Gourav
27
oran park
VE06C Omega
i removed left side both globe first and after that right side but light is still on. The problem is light stay on all the time without pressing the brakes. Need to take out the fuse
lout
60
Langwarrin Victoria
oh dear, that does sound like bcm
have you checked your trailer wiring connector for shorts
how handy are you, you may need to fit an additional brake switch, just to operate lights, will need to keep brake pedal sensor for other features
Gourav
27
oran park
VE06C Omega
i don’t know anything abt bcm or how to do it can you please help me how to do that or suggest me anyone who can do it for me please
lout
60
Langwarrin Victoria
repco can send your bcm to be repaired, but turn around time is a couple of weeks
or get an auto elec to cut the output wire from bcm to brake lights
fit a normally closed switch, held open to brake pedal
using a relay to switch negative and output to previously removed wire from bcm
Gourav
27
oran park
VE06C Omega
Thanks mate
