anarklov3r
- Aug 18, 2008
- 665
- 8
- 18
- Location
- Melbourne
- 2007 WM Caprice
Hey Guys, Started a little project to keep myself entertained over the weekend. Decided to build myself a OTR CAI for my WH LS1. I aimed to built an OTR that I can run with a MAF, but also take off later if I wanted to.
First up I did alot of measuring, trials with pieces of cardboard etc just to gauge how much room I have to play with. I also had a look at a few other OTRs on the net to see roughly how they all sat.
What I ended up with in the end was this "prototype":
A couple shots showing the OTR prototype installed in the car:
Remember, Safety First!
Next I cut the shapes I needed out of 0.6mm sheet metal with a jig saw and bent to shape (don't have any photos of this stage) but here is a mock up of it all sitting together:
Next I started to weld up the sheet metal. Note, I have never welded ANYTHING before and this is my first attempt using my old mans MIG welder with the aid of YouTube videos for advice:
Bottom Half Done
Top Half welded on and test fit the K&N Filter:
Rear Plate welded on with 100mm pipe attached:
Just need to drill a hole to fit the Air Temp sensor into the back of it, and maybe weld some tabs onto either side to secure it down (I don't like how other ones sit free) Other than that, maybe some heat insulating padding on the bottom to help keep it cool.
Plan to get this powder coated and should look pretty good!
Bottom Half Done
