Buying rb25/30 rebuilt engine but want to change pistons & rods
vl_2010
VL berlina
hi, so ive tracked down a rebuilt rb25/30 to go in my vl, now the only thing im curious about is the pistons and rods, the ones in there are for a turbo setup so not enough compression so im thinking of putting a piston ive found which gived 9-1 compression and a set of arias forged rods rated up to 10000rpm, im thnking of running 7500-8000 rpm. is it a simple swap over of pistons and rods? or something else will need to be done? any help appreciated
db_notso
diagnostic technician...
sunshine coast, qld
vt v6, mods(susp brakesetc...)
agreed and the obvious gaskets and all bearings to suit new caps to other crank...
walesy
Aint no family cruiser!!!
37
Perth SOR
Cherry Black WH II Caprice, VS exec wagon
ah i see. now clarify why you wouldnt fit a turbo to it
exactly what i was thinking, just turbo it, the motor is already built for it
