gibbonsVS
- Oct 6, 2005
- 14
- 0
- 0
- Age
- 35
- Location
- Brisbane
- VS Exec
Has anyone had any experience fitting corvette c4 brakes on vs commodores. The c4 calliper i am referring to is a pbr twin piston with a finned aluminium housing and looks very similar to the VS GTS. I haven't been able to find any part numbers to confirm it is the same calliper, but a search of a few different brake websites show it accepts the same pads as the VS GTS calliper and also has a 28mm rotor. The c4 however takes a 330mm rotor compared to 328mm for the GTS.
If possible I would like to fit the c4 calliper with the GTS rotors on my VS. I realise these brakes aren’t as good as the modern twin pistons available, but I would prefer to have original looking brakes.
* Does anyone know if the c4 calliper is compatible with GTS rotors?
* Are the twin piston callipers fitted as standard equipment on some of the higher level hsv v8s from vn – vs interchangeable?
