Cam ideas for 308
Cooperpurcell
22
308 sigma and 2005 vz clubsport
Hey fellas got a 308 in a sigma building for the pad just wondering wjats the biggest most aggressive cam you recommend for a 308??
someguy360
The Shed
Various
You've got to choose the cam to suit your compression, trans, stall, rear end ratio combination.
Just gonig for the most aggressive cam could make the thing lose power compared to stock in a lot of cases with holden engines unless the rest of the enigne around it is built to suit.
If you can give us an idea of your build then we can recommend from there.
I remember a mate years ago putting a 286 crane cam in a stock EFI 304 and ended up losing about 25rwkw compared to when it was stock because he didn't choose his cam to suit his engine combo as he had nowhere near enough compression.
Unfortunately with Holden V8's they aren't like LS engines where you have 100's of different cams available you can just slap in and send it.
gtrboyy
vt ss & lc gtr
Stage 5 camshaft :cool:
shane_3800
35
places
vr commo
If you watch Richard Holdners videos he tests big cams with low compression and what you said is not correct.
Compression brings power up accross the power band. The reason cam manufacturers recomend higher comp on more aggressive grinds is to make up for the loss of bottom end power same with diff gears.
The stall converter thing is for launches so you're in the peak torque when you launch.
Vin999
SA
VSedanS
Its only a skid pig then stick any cam ~!?>"@ you like until it goes bang and pushrods go thru the rockers. :p
