CAS Errors....again
dj_eddie
47
VT Berlina S2
I finally got around to changing the Crank Angle Sensor on Sunday.
Every was fine, the car started, i drove around to several places afterwards where i turned the car off and on.
THir morning however, its not the same.
THe car just cranks. and thats it, it wont start.
The fault codes read:
46, 47, 48, 49
Any help wouold be awesome!!
Eddie
I have NRMA coming over the check it out as well. Ill let you know how that goes.
dj_eddie
47
VT Berlina S2
Ok,
NRMA came.
He suspected the fuel pump, but that was fine.
He pulled out a spark plug lead to check for spark and was no spark.
He suspects it may the module underneath the coil pack. Since i changed the Crank Angle Sensor yesterday he said the module may have decided to
sh1t itself.
I reset the battery and got the same codes:
46, 47, 48 and 49.
dj_eddie
47
VT Berlina S2
Ok - Me Again.
I put the old CAS in and hey presto it works again.
KiWi1
11.00@126 Miss dat ****
HIGGINS RACE DEVELOPMENTS
Dead 11sec VX SS, Defected VP Ute
Wrong one was it? had that prob on my VP ute, chucked the wrong one in, even though it was off another VP, P/N was wrong, cleaned the old one up, fixed the loose wire (the actual problem) put it back in, presto vvrrrooommmm
Simon
KiWi1
Just for sh1tz n giggles,
Code 46: No reference signal from ignition module while cranking.
Code 47: No 18 X Reference Signal From Ignition Module.
Code 48: Camshaft position signal missing
Code 49: Cam/Crank signal intermittent
Simon
dj_eddie
47
VT Berlina S2
kewl - one thing though. Yesterday after i put the old one back in, it fired up normal.
This morning, the Mrs started it and it was idling very lumpy, so she jumped back into the Mother-In-Law's car to go to work.
Thinking of resetting the codes, how long should i disconnect the battery for??
KiWi1
2-3min. Have a p1ss, smoke wateva LOL. Just disconnect the neg terminal. Why dont u check the codes again, before ya do it? peace of mind.
Simon
dj_eddie
47
VT Berlina S2
lol - will do that tonight.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
10 seconds is all you need.
It may be a problem with the loom or the plugs in the PCM causing all those error codes. Make sure they are all clean and tight.
dj_eddie
47
VT Berlina S2
Ok, i found the shuddering problem.
Lead 5 socket was fubar'd. They were 8mm boash leads. The spring inside the socket was screwed up and was preventing it from being plugged in properly.
So anyways, all is running smooth, and no error codes yet.
Cheers to all contributed!!
Eddie
