TOMCAT85
- Dec 10, 2009
- 89
- 0
- 6
- Location
- Adelaide
- 2015 VF SSV -Redline, Herron White.
Ok, ill start from the beginning.
Car started running bad a few weeks ago and the engine light came on, drove straight to a mechanic friends place to look over the car and he couldnt see any Visual issues, i borrowed a maxiscan OBDII to find the problem and found that it was misfiring.
He reccomended to change the plugs first as this would be the cheapest option, so $200 later and new plugs car runs fine for 30mins then light comes on again. This time it says low efficiency in catalytic something or other.( Sunday Arvo)
I decide that a more serious problem should be covered under extended warranty so i ring my local holden dealer the following morning and book the car in for the first available slot which is the friday. Over the next few days the car starts to run worse, starts blowing smoke, struggles to start a few times. Friday morning comes and i drop the car off at 8.15. They ring me at 9.30 to say that coils 1 and 3 and being changed and its all paid under warranty.
Picked the car up at 2pm, the girls says to keep an eye on it and ring if theres a problem. It ran fine, although something didnt seem right in the feel of the car. 3.30 comes along and engine light comes on again. i ring holden and get told to bring it in monday morning again.
Takes them most of monday to find out that apparently it needs some software update to reset some parameters or something, and also one of the sparkplugs i changed needs to be replaced already. probably due to the misfiring. $55 later and the cars fine again. That was last monday and then on friday just gone the light comes on again, plugged the scanner in and it says the same fault, P420 i think it was. anyway rang them and had it go in today only to be told that my extended warranty through allianz doesnt cover anything to do with the exhaust (Not impressed) and that its the right hand cat converter thats stuffed, possibly melted inside due to the misfiring and that a new one is $1200 fitted.
Ive rang around and got prices on second hand or after market ones, just wanting any info people might have on swapping one cat with after market or should i just bit the bullet and fork out the $1200. i also got told that the v6 and v8 cat is the same and that i could get a v8 one from an exhaust place 2nd hand, but barely used due to someone buying a new car and replacing with aftermarket straight away for $550 fully fitted.
Any help would be appreciated.
