B1325 - Diagnostic Trouble Code Description:
Device Power Circuit
Possible Sensor Faults
Heating, Ventilation, A.C. (HVAC)
Possible Related Diagnostic Trouble Codes
DTC B1325
Circuit / System Description
With the ignition in either the ACC or ON positions, the HVAC control module should receive a 12V power supply. DTC?B1325 will set to indicate the B+ positive supplied to the AHLL control module is below the threshold.
C0899 Diagnostic Trouble Code Description:
Device Voltage Low
EBCM
DTC C0899
The electronic brake control module (EBCM) monitors the ignition voltage level available for system operation. A low voltage condition prevents the system from operating properly.
U1401 Diagnostic Trouble Code Description:
No Communication with MSM (Memory Seat and Mirror Module)
Memory Seat Module
DTC U1401
The SIM continuously sends a communication signal to the MSM. Upon receiving the signal, the MSM sends a reply signal, confirming that it can communicate.
There is no information for U0151
If you have any more codes, use this online tool,
www.carmodder.com • Search Diagnostic Trouble Codes
