Change VT dash cluster from 1 to 3 windows
MattLee
Mildura
VT Commodore
I have a 1998 V6 VT Berlina witht he 3 window dash cluster that was recently written off :rip:
I've bought a 1998 V6 VT Executive I've been in the process of changing things over between the 2 cars and was wondering:
Can i just do a straight swap with the clusters (I've been searching the forums for a few days now there seems to be some mixed reactions)
Apparently an airbag light will come on
The odometer in the exec is 230k and the berlina was 220k (So i think i have to go to a holden dealer to get them to use a tech 2 to change the kms and reset the airbag lights?)
I think thats all i need to know. Any help is appreciated
TonyJZX
East Coast
Commodore M6
tech 2 reprogam
can be $50 or $250 depending on who does it
MattLee
Mildura
VT Commodore
Aw well, cant hurt to just plug it in and see how it goes, worst comes to worst just change it back i spose.
Now i gotta find a thread on how to pull it apart lol
anarklov3r
2007 WM Caprice
You cant reprogram your ODO to match your old KM's easily. You have to go to a cluster specialist and will cost $200+, not worth it. Airbag light WILL come on if configuration is different. also, your berlina would have had climate, that will also need to be changed in your cluster.
thekid93
brisbane
vt s pack
try taking out ur battery b4 you change them over?
not sure if it work, but thats what i heard
for the airbag light that is
wrx884
WA's ASR Rep
37
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
if ur belina cluster has the white back housing it can b changed no worries with a tech 2. but theres a few more features in the belina cluster over the exec 1 so u'll need 2 get other things rest and adjusted 2 suit say like ur pre tensioners, diff ratio (if changed) wheels size ect.... aswell as ur air bag will need re programing. Dr bob on this forum does them. did mine years back 4 only $150
If u got the black housing u should b fine also as it has less KMs u can always add on the KMs but u cant take them off if the cluster has gone over 100kms. Black housing = VX cluster, White housing = VT cluster
climate control wont have anything 2 do with the cluster im pretty sure as thats a BCM job
Dayvo
Because i can
64
South East,Victoria
VE SV6 Series 2
Dr Bob is doing one for me . The info needed is engine & trans type, tyre size, airbag setup, cruise, lpg, trac control and climate control .
MattLee
Mildura
VT Commodore
Seems like a pretty major hassle, Seriously rethinking whether i want to swap them now haha
wrx884
WA's ASR Rep
37
Theres no hassle its all plug and play. who eva uses the tech 2 unit 2 change ur cars details ect.... just needs ur cars details that the cluster is goin into so everything matches again.
