dassaur
- Jun 10, 2020
- 1,321
- 1,211
- 113
- Location
- Sydney
- VF Calais V V8 Wagon
Alright. Job done! Took maybe 20 minutes. Jsat (post #28 above) was absolutely correct and helpful. I found using a small flathead screwdriver made easy work of the plastic weld, since there isn't a whole lot of wiggle room in there. The clips that hold the new door frame in were a pain to get on, but a 10mm socket fitted beautifully over the top. Using my impact driver, I attached a 10mm socket, put the clip on the door post, and pushed down and let it drive on. Worked well. I used a cheapo socket as there was some surface damage on the socket (not much).
Attached is the finished product.
To summarise, get the replacement door handle, which should include the handle and the clips. In my case, the hanlde was front rh, #92509304. The 4 clips are part # 13360088. To be clear, I didnt order them separately, they came together. Purchased from an ebay link provided in this thread.
