john_in_nz
- Feb 20, 2009
- 3
- 0
- 0
- VY II Adventra LX8
Guys I've VYII Adventra and the Climate control system is driving me crazy. I have the temperature set at 20 and it's nice and comfy then suddenly it starts to pump in hot air and the car gets really hot. Even the missus who likes the car to be hot complains it's too hot.
I turn the temperature down to “C” and it cools down, then I select say 18 degrees and it ok for a while then it suddenly decides to pump hot air in again.
Any clues on what is wrong _ I've done a search and all the problems seem to be about the vacuum changing from one vent to another rather than temperature changes.
It also does the same thing when the climate control is switched from Auto to just A/C setting. recently we have been resorting to driving with the whole system turned off and just the roof open, but the same bloody thing happens no heat is coming from the vents then all of a sudden it decides to heat the car even though the heater/ climate control display if turned off.
The local dealer has supposedly fixed it by changing a sensor by the steering wheel but it still goes hot and he now reckons he has to pull the dash apart and replace the control module - his estimate was a couple of hundred for the module and then a day and half labour to install at their rate of $80 /hr I'm looking at over a grand to fix - Hence I'm not keen if there is a quick fix someone knows off
