dephilile
- Jun 27, 2005
- 480
- 9
- 0
- Age
- 38
- Location
- Morayfield - QLD
- VT Executive S2
Hey
I recently noticed that my clutch is really easy to push in almost all the way and I have to push it right up hard against the firewall to disengage it. I had a quick look at the reservoir for the clutch fluid and it is empty. I had a look at I think it’s the master cylinder (the one connected to the clutch pedal) and it doesn’t appear to be what’s leaking. It was too dark to see much under the bonnet so I’m assuming the problem is with the slave cylinder.
I was just talking to a mate and he said that a friend of his had to get the slave replaced in his V8 VT except it was quite a length and costly exercise because it is hidden inside the bell housing and lots of stuff has to be pulled out to get to it.
I own a V6 VT. Am I going to be faced with the same problem? And if someone could give me an indication of how much it would cost that would be great.
Thanks
phil
Thanks
phil
