vs ute III
So I am in the process of changing the water pump on VS V8. On taking the bolts out some of them have a black liquid that is really smelly.
I don't know if this is a coating such as grease or if it is coolant that has become very hot over the years.
Also on the ends of the bolts is a white goo that may be some sort of silicone. The same white silicone is between the spacer plate and the gasket, however there does not appear to be any silicone between the gasket and the block, just gasket and it came off fairly cleanly.
So do the bolts come into contact with the coolant and if so should I smear a bit of RTV sealant on the bolts? The Gregory's manual does not say any thing about a coating on the bolts.
Also, the Gregory's says to use RTV on both sides of the gasket but as noted above , there did not appear to be any RTV between the gasket and the block. Is RTV the best or could you use a non hardening sealant such as permatex aviation?
I want to get it right as it is a #@&* of a job and I don't want any leaks. The last water pump I done was on a 186, what a breeze that was, it was also a long long time ago though.
Thanks for any advice.
