Codes
Drawnnite
Obviously Unsensible
2000 Vs Ute
System Voltage Malfunction
From some quick research, it will be the PCM has detected the Voltage to be out of the normal range.
May have just been a one off, could be battery, alternator or similar starting to play up
krusing
Melbourne, Bayside
Most likely the Alternator and/or the Regulator,
Check the Charge voltage of the alternator with a Multimeter at the battery terminals while idling,
Std voltage idling should be approx. 13.7 > 14.4,
While idling, turn the head lights on and the regulator should compensate for the voltage drop & current draw.
Anything out of the range indicates it could be a alternator/regulator issue.
Gazzathegreat
Vz
Thankyou for your time , to reply.
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
eny codes just google them
