coil pack seals
hr66
60
sadlier
ve calais v6
I changed the coil pack seals on my VE 07 v6 as oil was leaking out the top of 3 seperat coil packs onto exaust after a day one coil pack leaking again can anyone tell me why thanks
SV607
Holden Commodore VE SV6 & Holden EH Premier
they also have coil pack seals.. i had the same problem.. ordered a set from holden and my mechanic fitted them.. u remove the coils and press the seal in. and then fit the coil back.. i did all the seals of mine.. as i had chains done so they did the new seals while it was out.
Fu Manchu
WA.
Modify the PCV valve. A build up of crankcase pressure will start forcing oil out of all sorts of places.
hr66
60
sadlier
ve calais v6
i had my chains done a year ago so all were changed then too so i think some other problem i changed all gaskets and seals on the weekend and one leaking again where is the pvc valve located thanks
shane_3800
35
places
vr commo
The coils have a water/dust seal.
This is different to the engine tube seals where the oil will come out.
hr66
60
sadlier
ve calais v6
i know i took the tappert covers off and changed the engine seals and new tappert cover gaskets
hr66
60
sadlier
ve calais v6
engine tube seals i mean
shane_3800
35
places
vr commo
Did you install them the right way around?
