Dazza18567
- Dec 26, 2022
- 5
- 2
- 3
- Age
- 44
- Location
- b bay
- VE SS 06
Ok so ill make this short i got given an old VZ 2005 as the computers were stuffed and had the low fuel no start error
The relay bypass got it started no issue hooked up the obd2 and found the errors it had ABS fault and the low fuel error
so i swapped out the ecu bcm and pim i had from an old VZ known good computer all good
she now starts with the key correct specs 588 mid ect exact same
My issue now is its throwing like 8 bcm codes crank angle o2 sensors camshaft left bank high voltage bla bla and the check power train
message comes up on start up
it drives fine runs really well to well to have all the errors it s throwing but im curios as to why the old BCM ECU and PIM didnt show these errors if the engine actually has these malfunctions to begin with anyone got an idea on why it may be ?
I had one thought that the ecu calibration maybe set to a different engine / make and model would that cause these kind of issues ?
