myksomerville
- Feb 16, 2014
- 65
- 12
- 8
- Age
- 53
- Location
- Armidale
- Ve SSV S2 Redline
So I have a coolant leak that I'm trying to get to the bottom of.
A while ago the overflow outlet nozzle on the radiator neck snapped, and I puttied it up as a temporary fix until I could afford a PWR radiator (I prefer to fix things with stronger solutions).
Everything has been OK until recently, I have found coolant getting sprayed on the drivers front wheel and frequently need to top it up.
I bled the system Thursday, and had a temperature warning Friday that vanished and didn't come back. Radiator took around 3L top up.
Getting under the car, the bottom of the overflow is pretty stained from spray but I can't see any signs of a definite leak from either the radiator or say a cracked overflow bottle.
I'm thinking that the putty is failing and stopping a vacuum forming in the system, so the coolant boils and can't suck back to the radiator.
A mechanic friend thinks its head gaskets.
I'm probably going to replace the radiator with OEM in the hope that this fixes the problem. Is there any way to verify whether it is the head gaskets?
