Ckirkhoff
- Jul 5, 2008
- 27
- 0
- 0
- VS Ute S3
Hi all...
I have a problem with my VS III V6 Ecotech ute.
It is coughing and choking when I put the accelerator halfway down or if I go up a hill or anything that require the car to pull a bit harder.
It seems to slowly get worse and worse. Also a little more noticeable when it has warmed up.
It doesn't come up with any error codes and I know it is not the gearbox, cause it makes choking notices when pumping the accelerator in Neutral.
So far I changed the fuel filter, air filter, leads, spark plugs and o2 sensors. So all the cheap option are done ;-)
I did some research on the net and this forum in particular, so I think I have nailed it down to be one of the following parts:
• Fuel regulator
• CAS
• DFI and coils
• Throttle body
When I changed the fuel filter I noticed it was pulling hard and no choking, so I thought it fixed the problem, but when it warmed up it was back. Just feeling it was going great for a moment makes me think that it can't be a bad cylinder compression. And also... Wouldn't that eliminate the DFI and the CAS? Wouldn't they either work or not work?
I might add that the other day the Engine fuse blew. I replaced it and it was fine. Don't know if that makes the diagnosis easier.
What are your thoughts, what would you change next. I am starting to have to change more expensive parts and would like to try not to change all the working parts.
Hope anyone can help me with this little problem.
• Fuel regulator
• CAS
• DFI and coils
• Throttle body
