Cracking VN ECU
coolngroovy
Mackay Qld
MY06 VZ Calais
G'day.
Is it possible to change the thermo fan trigger point on a VN ECU (V8)?
I need the thermo to cut in earlier than stock.
If so, any idea who can do this?
Thanks.
_R_J_K_
Zenki S14
You can contact The1 or Delcowizzid on this forum to have a look at a tune for you.
Keep in mind that if you're going more than 40kph (I'm guessing this is a burnout car though?) the ram effect of the air will keep the car cool and the thermos won't do anything.
2INIL8
VH COMMODORE 308
Look up ace performance tuning.
coolngroovy
Mackay Qld
MY06 VZ Calais
No, it's a streeter.
The simple solution would be to wire in a manual switch. But i'm not going to rely on the mrs turning the fans on manually.
Immortality
Staff member
Sth Auck, NZ
Have a look on the PCMHack forum.
It's fairly simple to do and any number of members on the forum should be able to do it for a small cost.
