Take harmonic balancer off, need 1 1/4" socket? and rattle gun. Other option is put breaker bar on chassis of car and crank car, lots of caution this way!
Undo CAS adjusting bolt, 7mm?
Remove CAS bracket, CAS comes with new one 1/2"?
Fit new CAS bracket.
Sit new CAS in, do not tighten yet
Slide harmonic balancer back on, all the way
Use a small mirror to adjust CAS, make sure there is clearance for on Harmonic Balancer teeth so it doesn't rub
Pull Harmonic Balancer off when it looks right
Tension CAS and put Harmonic Balancer back on
Turn Harmonic Balancer by hand, make sure it does not run and check with mirror again
When OK retension Harmonic Balancer bolt
