ScottSV6
- Jun 16, 2011
- 50
- 0
- 0
- Location
- Sydney, Australia
- Website
- www.superiorshine.com.au
- 2011 SV6 Ute
There are abrasive polishes and non abrasive polishes. The term 'polish' is widely misused. In ideal conditions, there's no need to 'fill' anything. The finish is refined to a point beyond the point of even being fill-able. The idea is to actually remove any polishing oils after machining, that can fill as well, to make sure there is nothing left to be filled - ie, leaving clean, perfectly refined paint. There are guys who have been in the game much longer than I have who will be able to word that better (^^^ Like Scott.. Hi Scott) - but hopefully that makes sense.
To use the sand paper analogy, there are different grades of sand paper, in the same way that there are different grades of polish. Aggressive compounds and pads remove scratches but will often leave hazing and holograms - so you refine with finer grades of polish and pads, until the finish is crystal.
You have worded everything better then i would have.
You would probably put them in these categories:
Cutting Compound
Abrasive Polish
Finishing Polish (Abrasive) and also (Non Abrasive)
All in One > Basically a Finishing Polish and Wax in one, most of these also contain fillers.
Wether its a Cutting Compound or an All in One Polish they are all classed as "Polishes" as they refine the paint work which is what the term "Polish" means, the word "Cut n Polish" refers to no particular type of product, its just an old term that refers to cutting the paint work then polishing it.
Most polishes contain abrasives, it just depends how abrasive they are as to what category they fall into.
I could ramble on but its getting late. LOL
