Whoa boy!
Set those gains correctly first!!! you will kill your subs otherwise,
also make sure the load presented to the amp is within its safe range.
When using 2 woofers, you need to know the voice coil configurations to tell exactly how to wire them properly, are they dual 2Ohm or Dual 4 Ohm voice coils? or single 4Ohm or 2Ohm?
are they wired in series or parallel?
These 3 things are all important to the setups safety and longevity plus how it sounds.
You want the maximum for your gear mate, setup is where its at.
