the top control arms are the 2 arms that connect from the top of the diff to the chassis about about 25cm long from memory. check all your bushes whilst your there though. sometimes it paysto fit aftermarket adjustable ones so that you can correct the pinion angle as well. some come fitted with a spherical bearing on one end which allows the suspension freer (spelling??) movement through it's range of motion as normal bushes can bind a little. also if you haven't already i would recommend nolathane type bushes, they flex/move less to maintain better suspension geometry
