Diff???
ChoCo94
WA
VX S Pac L67
Hi all, just wondering will the diff out of a v8 vk wagon fit a v8 vk sedan?
bjwynd
mortlake
vb sl
Yep it will fit but you have to cut the mounts off and weld the ones off the other diff on I have done this before
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
Don't do it, way to wide scrubs like buggery. Also you have to be careful welding bit onto it, due to loads it will take.
bjwynd
mortlake
vb sl
iv done it with 8 inch wide tyers on didnt scrub on me
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
Got one in my sle, with a load scrubs on passenger side.
hiy_po
VK Executive
Maybe your panhard is bent or you need an adjustable one.
No the diff will not fit without modifications as stated above. Surely it would be easier to get a VL sedan diff and put that in. I have just fited a VL 3.08 28spline LSD to my VK sedan and it just bolted straight in, got to be easier than having to change all your diff mounts, or look for a swap maybe someone with the sedan diff you want will want your wagon one, or just change the internals over to a sedan housing, but thats not that easy to do with out some prior knowledge either.
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
Nope not bent at all and have tried an adjustable one too. The diff is a few mm wider than a VL sedan diff, a few mm shorter than a VN sedan diff. Wide buggers.
Also, its lowered so the tyre that should scrub would be the drivers side.
ChoCo94
WA
VX S Pac L67
yeh its not for me as such but one of my dads work mates is building a group c replica and bought a v8 wagon lsd and the n discovered it didnt fit and was wondering if it was different diff or out of a different model and if i was to get it rewelded i would get the welder at work to weld it for me
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
How about changing the centres over?
ChoCo94
WA
VX S Pac L67
it doesnt really matter i dont think he bought a vk wid a cut down 9 inch and was having brought over to use as far as i know
