vnv8driver
Banned
- Aug 30, 2007
- 992
- 12
- 0
- Location
- Up your mum
- 304 Calais
By popular demand i will go through in detail the basic procedures in which you need to do to paint your car. I can only explain myself so much on the computer and alot of the work, painting especially, comes down to experience and to have a feel for certain things.
TOOLS-
-Closed off space(garage or shed)
-Any half decent air compressor, extention hoses, gravity fed gun, orbital
-10 sheets/pads of 800 wet and dry sand paper
-Bucket
-Rags
-Lead lights
-Acryllic Thinners
-Prepsol
-1-2 litres undercoat
-4 litres acryllic paint from autobahn
-1-2 litres clear of your choice
-2 heat lamps
-1-3 litres acryllic spray putty
-Tape
-Newspaper
-Expensive Mask
-Extraction fan
Most of the work involved in painting a car is the preperation work, sanding, sanding, and more sanding. Start off by making an enclosure in a hot tin shed or a garage, i used large vinyls to cover my roof and walls supported by some timber i had lying around. Drive your car in and make sure all the windows are up. By using the tape and newspaper you want to completely seal up every single crack around your door locks, bonnet washers, all glass and rubbers/trims not being painted, etc. Because you will get over spray on things and even though its not hard to take off it is annoying and gets into everywhere!. Now come the most repetitive part of prepping, Go and buy an orbital, 2 if possible 1 large one and 1 compact one. Get about 10 pads for each. The grade needed depends on the condition of your paint, in my case i already had a custom paint job, spray putty,etc so i needed a rather coarse type. I used 800 and thats good for keeping the surface your sanding smooth and still takes quite a bit off. In most cases you want to sand all the paint off pretty much to bare metal. Do this by apply very light preasure to the orbital bearing in mind that if you leave the orbital in the same spot youll both heat up and distort the paint as well as make the surface uneven. You want to be always moving the orbital when its on, lean over what your sanding and move your hands up and down, you want to be sanding up and down every second or so.
When you have sanded to what you think is best, you can turn the compressor on and grab your gun and stand, pour the spray putty into a tin can (up to around 3 gun loads). The rest that is added to the mix is thinners, add around a 1/4 to what you have whilst stirring it. Pour the mix into the spray gun and connect the gun to the lead hose. You want to have the gun adjusted to fan and blow to your liking and so the paint wont run. Next, when your painting you want to have the gun dead straight with whatever it is that you are painting. You want to be around 15 cm's off the panel and whilst spraying you need to have the gun moving at all times. Spray the panels left to right evenly and at a brisk rate. When you pull down the trigger you want to have the gun already moving and when you take your finger off, run the gun spraying off the panel then realease the trigger. Spray around 1-2 litre on your car very evenly building up thickness where you need to repair panels or even the paint up. Let the putty dry for about half an hour then you can get back to the sanding!, sand the panels until every imperfection and wave is gone because when your painting the final coat youll be able to see evry imperfection. When the car is sanded to the best of your ability, wipe down the dust with a rag and prepare to lay your undercoat. Same as before, after washing the tin and gun out with thinners mix the undercoat with thinners and spray your undercoat evenly like before, you dont want it too thick a few mm is enough. Let the undercoat dry for 1/4-1 hour then wipe down the whole car with prepsol and a rag, make it very clean. Wash the tin and gun again and mix you final paint with thinners and paint 1 coat of paint on your car.Note- if your painting bumper bars or plastic, you need to also add a flex compound to stop the paint from cracking. Let the paint work dry for about 2 hours in the heat. go back and paint another coat and let it dry. 2 coats is enough but a third can be added. After the paint has dryed and set for around 4-5 hours you can go back and sand the paint with 1200 wet and dry to smooth out to the final finish. Wipe down the car with prepsol and a rag. Buff the paint with medium cutting compound and polish for a shiny finish.
You should let the paint cure for a week then add the clear. But remember to have the paint absolutely cleant and buffed. Painting clear is a bit harder and im not game enough to try it myself, that whats my mate will be painting. Its very easy to run the clear because chances are that the clear is enamel. A paint shop will charge bugger all to paint your car in clear and is best left to the experts.
TOOLS-
-Bucket
-Rags
-Lead lights
-Acryllic Thinners
-Prepsol
-2 heat lamps
-Tape
-Newspaper
-Expensive Mask
-Extraction fan
