Skylarking
- Feb 3, 2018
- 10,120
- 10,575
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
As long as the CPU still has the ability to process the required calculations in a given time frame, then I’d think the engine will still run sweet...... less error is less calculations the ecu has to consistently make from 02 feedback so the better the engine runs...
I’d thing if the O2 sensors have some large offset error that results in too large a LTFT’s being required, then there would be any issue to resolve. I’d think the correct way to resolve such would be to replace the O2 sensors so they read within the required spec and accuracy, not by reprogramming the fuel maps. LTFT is doing just as it is supposed to do (adjust fuelling for variations in hardware).
Obviously you can change the characteristics of the engine and make it burp and fart in different ways, or produce more power, all by playing with fuel maps. But all you’re doing is changing the factory compromises made to balance consumption agains pollution and power, given the standard tolerances of the hardware put into these engines. If in the process you set up the table to narrower equipment tolerances within your specific car that doesn’t make it run sweeter as such.
Put another way, if O2 sensors are reading correctly and within the limits designed within the ECU, the fact LTFT is not zero doesn’t really matter. The engine should still run sweet. It’s only when you have conditions which are due to a hardware fault (leaky or part blocked injectors, faulty O2 sensors) where the ECU can’t compensate enough to resolve the fuelling, then action is then needed. That action is repairing the faulty parts (not changing fuel maps).
The fact an engine may run better with O2 disconnected is somewhat irrelevant as that's the normal running mode but rather a fault situation. Still, it’s admirable but somewhat irrelevant
Don’t get me wrong, I’m not criticising, it’s either I haven’t understood what you’ve said or it seems what you’ve said is a little wrong (w.r.t the little this layman, me, knows about ECU’s and how they control engines).
Playing with ECU mapping is something that I’d be interested in once my car is out of warranty, so guess I have to increase my knowledge somehow
