Does a VZ have uni joints?
swift85
VZ EXECUTIVE 3.6 WAGON
just wondering if VZ's have uni joints on the tailshaft connection to the diff?
andyman
The Only 6sp VZ Wagon
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
yes, at either end of thetail shaft they are a rubber drive coupling
infront of the centre bearing there is a slip joint where they are joined and a cross and yoke uni
swift85
Andyman do these uni joint ever need replacing?
andyman
Orange, NSW
if they fail or worn yes
if the rubber goes, usually cracks and disintergrates - replace, the cross and yokes if they get play in the needle bearings, then overhaul the joint, centre bearing wears and flops about - replace, and slip joint normally dosnt wear
