Door key code
rustyguy085
VN Calais/VT commodore
Hey, does anyone know where to look for the key (blade) code on the drivers door lock? I have removed mine and i can't seem to find it..
I have just had a new key cut going off the original code (supplied by Holdens) but it seems as though the previous owner may have changed the locks.
krusing
Melbourne, Bayside
Firstly,
Its normally stored on the Security Card that you get with yhe Owners manual,
Or, you can normally obtain it from a Holden Dealer if you can provide ownership of the said vehicle.
Where are you ?
As you dont have a location in your Addy, so its makes it virtualy impossible for any JC member to can assist you !
It is normally stored in your BMC, that controls the Doors and imobliser.
Otherwise your on your own.
_R_J_K_
Zenki S14
Holden just look it up in their system using the VIN. Pretty sure it's not written anywhere on the vehicle.
losh1971
North Tas
VE Series I SS Ute
If you remove the lock and take your key to a locksmith they should be able to reset the lock to suit your key. I have had similar done before, when I have barrels but no key.
