Member 1
- Dec 29, 2016
- 116
- 7
- 18
- Age
- 45
- Location
- Australia
- VX
I drained the radiator and that gave me only 3L. The coolant is really dirty (damn dealer never bothered to check), I removed the overflow and that had 1L (the reading level was too high).
I thought I should get 4L or probably more when I drain the radiator?
I tried to fill the system with demineralised water and ran the engine until it reached operating temperature then drain it. It's still not clean.
Two questions:
1. Eventually, how can I add 6L of the coolant concentrate? I will not get a 50/50. I will get around 70/30
2. I tried to avoid adding tap water into the radiator. That is why I used demineralised water in the whole system. The problem is; coolant is really dirty. Should I flush the radiator with the garden hose? I live in an apartment and this will cause a mess in the shared lock up garage.
Two questions:
