Drivers power window
Bgfoot88
33
New Zealand
Vy series 2 by manual
Hi I just have a problem with my drivers power window. I was driving around town and it was working sweet now when I go to use it I can hear the relay clicking but all other windows work sweet. Any help would be much appreciated
Trevor loves holden.
vs commodore
I've tried that but I just keep hearing a ticking from by the relay
Did you also try pushing down with your hand as well? Try removing the switch plug and clean it, However, it can sometimes be caused by a broken sash clip or binding in the window track that's causing a mechanical issue rather than an electrical problem. You will just have to remove the door card and investigate, could be stuck could be stuffed.
