E series AP Racing 4 Piston set
abuch47
Madelaide
LSS3 YOOTE
5000km old
363mm x 30mm front 348mmx 30mm rear
good idea to buy slightly used set for a couple grand?
dgp
VF II SSV Redline
Are you looking to buy, or to sell?
If buying, no problem buying used, especially with those low K’s. take your verniers and measure the rotor thickness to make sure though.
You will also need larger wheels to clear, so you will need to check that out too. (your wheels look to be 18”)
abuch47
Madelaide
LSS3 YOOTE
yes I have 18" but been looking to upgrade for a while and found some cheaper hsv on marketplace. appreciate the response as I know nothing of brakes and value for money.
426Cuda
SUBLIME!
Wagga Wagga
VF Redline Sedan - A6 Spitfire MSE...
I've seen them for $1k on eBay.
HotdogNo1
QLD
VF SSv Redline A6 W407
5000km old
I brought a set of pre-loved E3 Hsv Brakes
Installed the 4 pot Ap racing calipers & rotors (bolt straight up) on my OLD VE SSv Series 2 with VF redline rims that clear the big brakes no problems. Rotors (Hsv)Front 365mm Rear 350mm
I used new Hsv brake lines on the front with new copper washers all round and new Hsv caliper bolts about $6 each. Machined the disks and new Rda extreme brake pads.
Also for the rear brakes, you will need to cut the dust cover at the back of the old rotors to fit the new larger rotors.
abuch47
Madelaide
LSS3 YOOTE
VE brembo (12mm) had different caliper bolt size to VF brembo (14mm).
But if these AP come with bolts should be sweet I spose.
Any known combos from AP/DBA/Brembo or the like that are cheaper? @gslrallysport
