eco tec v6 oil water problems
noongv6
wagon,low,cruising,5speed
qld
www.justcommodores.com.au
vs commodore wagon
ok so i purchased a engine off a guy told it was a runner!! put in start up after running for 10 mins radiator fills up with oil please help
noongv6
qld
vs commodore wagon
yeah manual mate yeah pull her apart an have a look the guy i got it off said it also had crank grind an new bearings so maby wen put together hes left something off under the front cover perhaps??? deffanitly be looking at the haeds an front cover cheers on info guys
frankenstein
2x 97vts and 2000 wh
definitely head gasket mate or if he has worked on it possibly didn't get the heads machined before he put them back on.
VZSS01
Adelaide, South Australia
VZ SS Sedan
Easiest fix might also be the water pump seal behind the timing cover so if ur heads do come off check that before proceeding further. Also has the timing cover been resealed recently??
