IBLOWN
- Sep 13, 2005
- 2,153
- 59
- 48
- Age
- 44
- Location
- Sydney
- VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
So... Lol. I decided to change out my head gaskets on the Twin Turbo from the leaky Cometics MLS to Felpro composite gaskets.
Put it all back together, went to bleed the cooling system and noticed it took alot longer than normal for the coolant to start to come out the nipple. When the motor cooled, the top radiator hose sucked in! Ive never ever seen that on this car before.
I eventually bled the system and took it for a good 200km drive.
I noticed the temp gauge sitting very slightly above where it normally runs but thought because i was doing mountain driving it was just getting warm like most cars.
Got to where i was going, looking for a parking spot. Starts overheating... Let it cool, no drips, radiator took about 1.5L of coolant.
Reservoir was full, didnt suck back into the radiator. I thought it was probably the cap. Cap is ok. The system is holding pressure to suck back form the reservoir.
Then i had a thought. I gingerly pulled out the dipstick. Chocolate milk and double the full level.
No oil in the coolant though.
Anyway, got home, pulled off the inlet manifold, new gaskets were still ok. Couldnt see anything wrong. Thats as far as ive got so far.
Cant see how its the new head gaskets. Im using ARP studs torqued to 75ft/lb.
Coolant is pissing into the sump from somewhere but not into the cooling system. Coolant is clean.
One thing ive noticed, before i changed the head gaskets was that the reservoir was NOT topping up the radiator. I kept having to top up the coolant from the radiator cap but it was losing coolant by blowing out the head gaskets under boost lol but not a huge amount. Nothing like its dumping coolant into the sump now. Oil was always clean. Im thinking as the motor was cooling, the cooling system wasnt holding pressure to top up the radiator. Im thinking coincedence.
Any ideas before i go to the trouble of 400 days worth of work pulling turbos and manifolds apart? Any quick checks other than pressure test and compression test? Ive got a feeling the compression test wont show anything until the motor is hot. Dont feel like getting burned by the turbo manifolds lol.
