Just did mine and I used Loctite MR 5923 same as 3J, used it on the gasket both side and the 4 bolts. Torqued them 4 bolts to 30Nm and the smaller ones to 21Nm book says 12-18Nm + 74 degrees, the water pump pully 4 bolts 16Nm. Didn't use the shim tried it on and spun it and you can see it not spinning like it should so removed it no more funny business, funny thing the one I took off had the shim so probably didn't need a water pump just the shim removed, someone before me fitted a PTX pump put the spacer on.
So many mixed messages about using it or not, the guide it comes with shows 2 types both having a hole in the centre of the pully mine is solid, a guy on U-Tube says you don't use the spacer after the VP Commodore not sure he was right or not.
