ECU scantool and airbag light VT commodore
johnandles
vt
Noob question..can the diy scantool erase the airbag light? if not what can?
Thanks Johnno
johnandles
vt
Iv'e anwered my on question..
Thanks for all the replies but..doin' a search revealed all.
Too bad the DIY scantool hasn't software available to probe further into the 'other' areas of interest! ..(imagine a home built Tech 2?)
Johnno
HARVZ-6
30
Riverton sa
VT spac super6
just need to be able to access body control section..
mine had the same thing.. was a pretensioner the whole time
mlinton74
Kallangur, Brisbane, Australia
VT Commodore Berlina Ser2 Wagon
I just replaced the drivers side pretensioner in my 1999 VT Commodore last week at $170.00 . I had the code cleared, the light stayed off for about 4 days before re-appearing again. Anyone had similar experiences....or know what to look for??? This is turning into an expensive expedition!!!
Staggie
VT Calais S1, VK Wagon EFI 5.0L
could be the clock spring, had exactly the same thing happen on my vt calais, ended up being the clock spring and hit the dead spot in a shopping centre car park.
db_notso
diagnostic technician...
35
sunshine coast, qld
vt v6, mods(susp brakesetc...)
if air bag light on you need to get the code for why then fix that circuit
either get holden to pul;l code and replace part then return to turn off light
OR
go to a workshop with an (expensive) scantool as they can access all modules too
REMEBER NEVER USE A MULTIMETER ON AN AIRBAG CIRCUIT
:bomb:
moose man
VXII
Rubbish. A multimeter of the correct type is perfectly safe to use on an SRS circuit.
91luxy
brisbane
vs v6 commodore&vs v6 91 hilux 4x4
the same thing happen on my vt 2 days ago i turned into a servo and when turning the wheel theb keys made a crunching sound or somthing there did and then the airbag light still dont know
svill123
VT Berlina S1 V6
exact same thing here, i turned into a survo and the light went on. I got a VT berlina had the code checked. - "31 - Drivers Airbag Open Circuit (Capacitance Too Low) - Something tells me it could be the clock spring.
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Mine also came on when turning sharply so I assumed it was the clock spring and it was but I'm sure the code I got was 21, but that doesn't mean that 31 isn't related to the clock spring also.
