kais3r
- Mar 19, 2014
- 211
- 2
- 0
- Location
- Qld
- VX Executive S2
Does anyone know how these EGR valves operate?
When they open and close...
Either throttle or temperature related
Is it always closed at idle or does it open based on idle temps...
Whether they should create a tight seal and let zero gasses through when in a closed position...
Just trying to to test and determine a possible fault with one on my car, I've tested it with a cold running engine and blocked off the TB inlet and it seems to raise the revs at idle under this scenario, but it shouldn't change anything if the valve doesn't let any flow through in a closed position, so it may be leaking or faulty, but once I know the workings of it I'll be able to determine what's going on.
Find it strange that if it's meant to be closed, and I block off the TB inlet, that the revs go up at idle, I'm thinking if it's NOT leaking then there shouldn't be a change in revs either way.
Thanks
Thanks
