hako
Donating Member
- Aug 1, 2004
- 8,020
- 96
- 48
- Age
- 80
- Location
- Toowoomba SE QLD
- VS11 BT1 V6
Check all connections to the relay and fuse block under the bonnet....maybe one of the fusible links is loose or corroded. Check all relays to see if they get hot during operation also tap them gently.
14.6V is too high for the alternator - should be 14.2V maximum...maybe the regulator needs replacing or the multimeter you're using is reading wrong?
Try turning the lights on etc and then with the engine running wiggle/wobble/gently pull all wiring basically everywhere till hopefully the fault repeats.
Before all this happened did you do any electrical work on the car?
Last thought - check the ignition switch wiring where it connects behinds the ignition key.
