engine just cuts out
Pimpin' VR
bendigo
HBD VY Commodore
when driving my 94 VR Executive the motor has just cut out and warning lights (oil, engine, battery) come on. when it happens i turn the car off then start it again almost straight away and it runs fine. this has only happened a couple of times but it is inconvenient. its an auto by the way. whats going on?
Harvs82
41
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
Definately a crank angle sensor, extremely common problem.
kopper69
VRII Acclaim
I wouldnt say definatly, but very likely to be crank angle sensor. If you check the codes (do a search) you will have a much better idea.
Dragz
SE.MELBOURNE
VZ
Hey bud,
Well i have the same problem....I went to mechanic and got CAS changed and it was okay for about 2 months and outa nowhere ban g it turns off while im crossing on2 another road i was like there shiting my self lol and i tun it off and it goes on straight away..what i think it could be is the fuel pump?...
well ye i still havent fixed it but cbf eather no money.
Dragz
BadSeed
VT V6 Berlina Wagon
I had similar problem, driving along and car would cut out.. sometimes wouldnt start at all..
had to get under bonnet and shake leads around dfi module, turns out it was a bit faulty, so sometimes plugs would touch, othertimes even while driving they would disengage (kind of annoying since you had to manually pop the hood and shake the wires, for sometimes upwards 5-10minutes to get car to start)... cost $220 at trade price to fix.
JD
Donating Member
37
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
i reckon fuel pump on the way out
