Cheap6
- Jun 19, 2005
- 2,498
- 74
- 0
- VP Exec
Knowing me it would take a week lol. Can you lift out the motor with the gearbox still bolted onto it, and just angle it so it comes straight out? Or do you have to unbolt the gearbox first? Could someone write up a quick explaination of whats involved, what to disconnect first, what to look out for etc? That would be greatly appreciated.
It is actually much easier to take motor and box out together, with an auto trans. car, because of the auto. cooler lines.
Some simple tips, reminding that there is more than one way to do it:
Disconnect the battery first thing.
Leave the coolant hoses connected, with the clamps undone, until you have finished working under the car, unless you enjoy showering in coolant.
The radiator fan and hoses can be left attached to the radiator and removed as an assembly.
You can avoid having to drain the trans completely by using a spare (wrecker or a discard from driveshaft workshop) front tailshaft yoke to plug the back of the trans.
Disconnect and loop the auto cooler hoses so that the radiator and cooler line ends are both sealed. Avoids a mess and prevents contamination.
The wiring harness for the speed sensors fits into a clip next to the trans and will be torn off when the engine/trans is pulled if not removed from it.
Undo the high pressure power steering hose from the rack and the low pressure from the reservoir.
Leave the A/C compressor connected to the hoses and disconnect it from the engine block with the engine partly out of the car. A very slim spanner will be needed to undo one of the bolts.
A digital camera is very useful for recording the routing of harnesses etc.
Undo the trans shift lever push/pull rod from the trans end (as distinct from the lever end) to avoid having to adjust the slide.
Refitting the engine mounts into the holes in the K member can be a little tricky. One side (or the other) is easy, both together is more difficult. The trick is to put one side into the holes, start the nuts one or two threads then do the other side by just resting the engine mount studs on the K member and pulling (twisting) the studs into the holes with a lever angled between the studs. (Without any human body parts between the engine mount and the K member as it drops into the holes).
