Hi,
Sorry about the slow response. The dish is 23.6cc but the pin height is 36.3 up from stock (35.5?) this makes for a pretty high c/r. with a deck height of .0 a head gasket of .050" bore of 3.840 and vn/r chamber of ~37cc these come in at ~10.2:1 good for the N/A race guys.
I have cut up a head to check the meat and have done a quick rework of the combustion chamber to gain 8cc's from it and turn it into a more open hemi chamber. In the morning I will cut this chamber also to check for remaining meat. I'm looking for a min of .200" remaining material in the chamber for strength. I will then make a jig to cut the chambers spot on with a hss cutter for the outline and hand blending and polishing to complete. Preliminary results give cr of 9.2:1 as I will be running a largish cam (cut from billet) and alky (metho/water) spray it's not to far off the mark.
The crown on these pistons also could be further machined in the dish, however I wouldn't advise removing any material from the squish area above the ring lands as the first ring is not *that* far down.
Steve, I'm guessing your looking for the mahle part number? The pistons are at the workshop so I'll have a look and get back to you on that.
cheers
Jay
