Error 44 LH oxygen sensor lean signal
Jaym
Warwick QLD
1998 VT Berlina
Hey guys
Just brought the wife a VT berlina and engine light came on, has done it twice now, both times I got a strong smell of unburnt fuel from engine bay.
Have looked for fuel leaks etc checked purge hose etc
Any ideas?
Code is 44 LH oxygen sensor lean signal
Jay
Cashman_309
VTII Calais
Could be a leak in the extractors setting off the sensor due to irregular flow or the sensor could be stuffed.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Vacuum leak maybe?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Sounds like it may be a fuel leak. Is there a reddish "high tide mark" around the manifold on that side anywhere?
Brett_jjj
Tamworth NSW
vs commodore
If its leaking fuel at the injectors where they sit in the inlet manifold, then its also gonna be sucking in air causing it to run lean on that bank.. The injector O rings need replacing.
Logz55
30
Kadina
Vt ss 5.7
Change your oxygen sensors mate
